Online: Soapbox2627
Loose mirror problem.
  • Boozo
    Boozo
    I've done a search of the messages and can't find anything simliar so will put this up.
    I went a bit crazy with the WD-40 a few months ago and like the cats around I here started spraying everything.
    Well I saw the bike mirror and gave a small squirt into the ball and socket joint on the back of my left mirror.
    Next time I went for a ride I hit a bump or two although nothing major only to find the mirror is so loose it gets knocked out of whack each time.
    Is there a way I can tighten it up?
    I've tried wiping out any excess WD-40 with a clean rag but it's still really loose. So loose in fact I'm amazed the wind doesn't blow it out of alignment.
    Don't know about you guys but I use my mirrors all the time even if it's just to spot the fuzz.
    Any advice would be appreciated, but I don't want to buy a new mirror for something so minor.
    Thanks, Boozo.
  • brucefxdl
    brucefxdl
    top job bonkerz,came home with same little problem today.looks like an easy fix.coincerdently my fxdl has just over 36k on the clock as well.cheers
    Remember the old days when you had a screw or nut to tighten - lucky we now have these modern methods :P
  • steelo
    steelo
    Thanks for posting that link Bonkerz. I'm sure that will come in handy one day. Regards
