Online: Soapbox2627
Urgent Assistance Required!
  • kaos1369
    kaos1369
    Putting the bike back together after a top end build. Have a plug on the throttle body that does not plug into anything, I can not remember what the bloody thing is for. It is the red plug in the photo, every thing else is sweet and has been mated. It has me stuffed!
  • xlr8it
    xlr8it
    It could be the plug that plugs into your original air cleaner, it operates the flapper on it. If you replaced the AC it is not used.
  • kaos1369
    kaos1369
    Cheers mate, that makes sense. I will pull the original out of the box when I get home, I have never seen the OEM one! Have a good one.
  • Retroman
    Most likely the 'Active air intake" system as described
    Only on export model bikes , US bikes don't have it but some models do have the "unused" plug in the wiring harness.
    From your photo it appears 'similar" to an O2 sensor wire when viewed from that angle
  • softfat
    softfat
    o2 sensor plug is more squarish with 4 pins. My rear o2 sensor decided to fuck up last week and my Harley dealer had to order one and it won't be here until next week. Couldn't have been the front fucker could it, as he had them in stock. Maybe an omen for me not to ride this weekend. No doubt it's for the air intake.
    Soft...
  • kaos1369
    kaos1369
    Thanks Bros, keep em coming. If all responses are similar Im puting the cunt back together.
  • Retroman
    O2 sensors looked like that until 2011 on Dynas and Tourers and Sportsters
    Until 2010 on Softails
    What is this bike and how old is it ?
  • softfat
    softfat
    Didn't know that Retro, thanks. Sorry to correct you.
    Soft...
  • kaos1369
    kaos1369
    2013 Breakout, I havent had a chance to sus out the OEM intake yet as I am at work. Sounds like you guys are right. Thanks for the info Bros!!.
  • Ando
    Ando
    auto decomp
  • kaos1369
    kaos1369
    Auto Decomp? What does it plug into? The auto compression releases coming out of the heads are plugged in (two of them). This thing is on its own with nothing to plug into. I get home this arvo, will have to look at the stock air cleaner as suggested. Cheers.
  • Ando
    Ando
    You have one plugged in wrong
  • kaos1369
    kaos1369
    The ACR's are on the other side of the frame, side by side and mated correctly. Should know when I have a look at the OEM air intake. Fingers crossed.
  • kaos1369
    kaos1369
    Thanks for all the responses. It was for the stock air intake after all. Bike is back together, sounds fucken awesome, now break in time then dyno!!!
  • Hound_Dog
    Hound_Dog
    I always, on any build, label or bag and tag everything! Im doing a build now on a vintage BMW where the owner just ripped, tore and busted his way thru everything. Its caused me a lot of headaches with the antique 6V DC wiring.
