Online: Humbug
Mobil VTwin 20w-50 full synth
  • shfunky
    shfunky
    Am going to replace my oil soon and am going with the Mobil VTwin, local guy here sells it for $15.03 a quart, is that a decent price ? , and can I use it in the tranny or primary?? Have read before there are oils you can use in all 3 holes but wasnt sure which type it was.
    I am using the Mobil VTwin in all three holes and have had
    no problems.
    I reckon it's great and will keep using it.
    I paid $13.50 a quart.
    Hope this helps.
  • Finny
    Finny
    Does anyone in melb know where to purchase this product
  • Peter
    Peter
    It costs me about $15 a quart.
  • Finny
    Finny
    Ok i emailed mobil direct today for a supplier in melb ...........They only sell box's of 6 qtrs @ $84 gst inc.........works out @14 each
    www.mobil1.com.au ........Email em for your local supplier
    And if you cant get it and want it pm me and we can work something out
  • lapua
    lapua
    I agree I use V1 in my Vtwin engine and use HD oil for the trans. Might try redline on the next service. V1 is design for the Vtwin engine and I will only use it for that reseaon.
