Go-Pro ride. You can almost feel it.
  • wozza fatboy
    wozza fatboy
    I've been using two Camera's on the bike and the Wondershare program for the lastest vids. This Video has the chest mount camera only with the rear camera's sound. Next week I'll have the video with the two views. You really feel like your the rider in this video and the noise from the Freedom pipes is wicked ever if they starve me of a bit of H/P. I'd really enjoy this video on a big screen with surround sound and a couple of cones or a nice joint to enhance the senses. Reminiscing.
    Did quite a few keys on the Fatboy feeling," enhanced'', fuck it felt fast. Hope you enjoy.
  • wozza fatboy
    wozza fatboy
    Mate, speeding is illegal, you know that. ?
  • Speedy
    Speedy
    Wozza ...
    What sorta "freedom" pipes ?
  • Speedy
    Speedy
    And ...
    Please remind us / me, what mods you have done on the bike in the video.
    P.S. love ur work man.
  • wozza fatboy
    wozza fatboy
    Thanks for that.Starting with a 2013 Fatbob 103cc. I wanted the most from the bike without a big spend. Performance and handling was my main goal. The Freedom pipes are dual turnouts. The ground clearance is really good and i got them second through Procycle Dyno when they did Stage 2 kit and Dyno. I went with Andrews 54H cam, Big Sucker Air Cleaner, Feuling HP lifters, S&S chain drive and easy start. A Full custom dual table map. Max Torque=108.11, Max power=96.88. A upswept Fatcat 2into1 will give better h/p. Suspension is Harley's heavy duty progressive suspension kit and shocks. Some short Arlen Ness pegs. This video I just had the Jims Cooling fans fitted,it was about 35 to 36degress with high humidity. They work well. I have one last mob to do. It is today. Changing the front spocket from a 32 tooth to a Jims 30 tooth at Procycles. On the highway i will be able to use 6 gear and 2 gear should be a hoot. Bang for buck, around 4k to 5k of mobs. Thats pretty good and afun bike.
  • JFE
    JFE
    Hands down best vid of the breed. Great work, and the camera/mic set up was spot on in my opinion.
    Out of interest, how come you went for the HD shocks and springs over some of the more well known aftermarket brands?
    Keep the vids coming!
  • wozza fatboy
    wozza fatboy
    The front forks seal was replaced under warranty, at the same time I got the springs, the rear shocks and helmet where last minute for Lakeside. Thanks for your feedback. I cant seem to add a comment to the things that are said from my mobile, just a quick reply. Next week I'll add the rear footage as well.
