Low rider guys..
  • Mr.Mow
    Mr.Mow
    Question for you, the battery cover.. Any of you know if the low rider lettering is just adhesived (good word eh?!) on? I'd like the cover for my Wideglide, but not so much the lettering.
  • Blackmagic
    Blackmagic
    They look stuck on but I will have a closer look and let you know.
    Moz
  • Blackmagic
    Blackmagic
    I just happened to take these pics a few weeks ago.
  • mitch199
    mitch199
    That black LOW RIDER section is just stuck on with double sided tape. If you heat it up with a glue gun, it will peel off leaving a bare chrome cover. Looks much nicer in my opinion.. But each to their own!
  • Mr.Mow
    Mr.Mow
    Ah thanks guys I see what it is now.. The chrome and black trim is a stamped metal bit and the letters are raised.
    Thanks, I quite like the chrome and black bit, was hoping the letters would come off.
    Next plan!
  • 78gold
    78gold
    Hi,
    I like the black and chrome look as well, so I had the local smash repairer paint the "band" black semi gloss,
    Also had my fork legs done the same colour (As well as some other mods like grips, pegs etc to match).
    Before
    After
  • Speedy
    Speedy
    Did he also kill something and lay it upon your seat ?
  • 78gold
    78gold
    Speedy,
    The Mrs loves the sheepskin,
    Anything that keeps her happy keeps me happy.
  • Speedy
    Speedy
    I know EXACTLY what you mean bud.
    Enjoy.
  • Lowrider762
    Lowrider762
    I painted mine using a Satin Black Vinyl paint from Bunnings, takes a while to mask it up but it turned out really good and definitely recommend it.
