Online: GGUser744
Rear shock options - 2003 Road King Classic
  • Jeffoh14
    Jeffoh14
    Hi
    I have just got a oil leak in one of my air shocks on my 2003 Road King Classic
    I assume its throw away and non-repairable.
    What is the best option for replacement of the shocks - What is everyone using for shocks and a good ride?
  • Ballsy
    Ballsy
    www.suspensionshop.org  good quality ,aussie made ,,,walter is the man custom made for your bike at half the price check it out
  • Neale
    Neale
    Hi mate. Dunno if this will help at all. But. I replaced the rear shocks on my 08 FLHT at 42,000 kms with a set of fournales. About $1300 worth. I had the cash and after 20 yrs of oohing and ahhhing them, I thought why not. Are they any good? Well after about 40,000 kms I have to say that they haven't caused any problems, that is they are reliable, the pressure never varies even after months of use. BUT!!!!! The original factory ones seemed to be the same. Although 99.9 percent of my riding is solo. If I was to do it again I would just buy another set of factory ones. When I bought my fournales I think that they were half the price.
