Online: GGUser744
fuel injection
  • madmax
    madmax
    Hi  Have a 1996 flhri roadking it is running rich and popping. have taken to dealer but they just charged me $600 bucks and said he dont know what to do so still the same . It has bigger cam and bigger injectors in it when i bought it but just started playing up. does anyone know if a thunder max would fix it thanks.
  • madmax
    madmax
    Thanks Scotty was thinking about that so that will be the way to go. all i would have to buy is a carb is that right and conversion kit for fuel lines. I will have to cut steel fuel lines out off tank also. thanks for all your help.madmax
  • kingchops
    kingchops
    Moved post to the workshop.
