Online: Stuart
2-1 Exhaust for 110ci
  • Kane.R
    Kane.R
    Hi all, I've just put a deposit down on the new Low Rider S and am looking at getting a decent 2-1 pipe for it. I had a V&H Comp Series on my Fatbob but found that the clearance was horrible and scraped around every corner. I'm looking at the RSD Slant. Just looking for advice as to what has the best performance/sound. Cheers :)
  • Daggs
    Daggs
    Consider the D&D Bobcat, I'm very happy with the looks, sound and performance of mine.
  • Kane.R
    Kane.R
    Thanks Daggs, I'll look into it :)
  • chriso
    chriso
    Ive been through the ringer with performance pipes.
    Also found D&D to be the best.
  • Mr_Bean
    Mr_Bean
    +1
  • Retroman
    When I got my 110" CVO Springer a few years back , it came with a V&H Big Shot Staggered system on it. Obnoxiously loud
    ( I had never been a fan of V&H personally up to that point!).
    I made contact with a guy in Perth who had bought the same model bike in 2008 and still had it.
    He had tried EVERY and I mean EVERY exhaust option available for 200 rear Softails from 2008 to 2011 and still had them all hanging in his garage
    You name it , he'd tried it 2:2 , 2:1 yada yada. Some forked the ground clearance , some were fugly and some ran shit via low RPM torque loss.
    His summation after all that ? Stock OEM Headers with "good" slip on mufflers , Khromewerks / S&S / Rush
    He reckoned ALL of the 2:1 systems were too loud , especially with the 110" motor , and most all of the 2:2 options as well
  • noctm
    noctm
    Got a mate with the RSD Slant on his Dyna and it does not have very good clearance at all - I don't know anyone with the D&D so I can't comment there
  • Kane.R
    Kane.R
    Thank you everyone for getting back to me, I really appreciate it. Finding the golden triangle will be hard (Performance, Looks, Clearance). Thanks again.
  • JFE
    JFE
    Mate, love my D&D Fat Cat (louvered baffle), and can't recommend it enough. The fit and quality looks great and I've only heard good things performance wise/tuning. It is louder than stock but not stupid. I could only imagine that other D&D products are just as good. I also dig that you can email D&D direct with questions.
  • Daggs
    Daggs
    Same with my bobcat, awesome pipe, not loud at all at idle and taking it easy but roars when you give it to her
  • chriso
    chriso
    +1 got fat at on both my dyna and softy and have produced best numbers out of all I've played with
  • Dutchy Hoogen
    Dutchy Hoogen
    D&D 2 into 1s good pipes. Only loud when you crack the throttle.
  • Undercover
    Undercover
    When is the Low Rider S available here in Australia and what are the dealers charging for it? I can't see any prices on the net for Australia yet.
  • Kane.R
    Kane.R
    Late April, should only be roughly $2500 more than standard. Basing that on the extra for the Slim/Fatboy S. According to M&W HD in Brisbane there are approx 80 coming into the country. Happy I got my deposit down early!
  • Daggs
    Daggs
    Nope, nothing...
  • Kane.R
    Kane.R
    Had a look in your pics Daggs. They look nice on your bike. I'll have to look into them. Cheers.
  • Kane.R
    Kane.R
    Was just looking on the D&D website. Apparently the Bobcat exhaust doesn't fit the '14-'16 Lowrider models. Will have to send an email off regarding the new S model.
  • chriso
    chriso
    try the fatcat mate
  • Daggs
    Daggs
    Cheers mate, I guess you have to go by what they say but I do t see why it wouldn't fit the later models, can anyone else shed any light on it.
    The fat cat is an awesome pipe too no doubt, I just wanted a shorter, sportier look.
  • Kane.R
    Kane.R
    Have been up all night looking and I've found one that appears to be half decent. The Two Brothers Racing Comp 2-1. Looks as though it has good clearance, plus I also like a shorter look to a pipe. Anyone seen or heard any of these in action?
