Online: WideglidingNZ
ABS problem
    Mario struggled to read you post but how are you aware that ABS is switching off at 55kph
  • Sparra
    Sparra
    Just wondering if it's normal for your pads to wear like that...4mm top,1mm bottom??
  • brucefxdl
    brucefxdl
    good day mario,may be one or more pistons in the caliper is partially seized or binding allowing the pistons with less resistance to move a bit easier causing the uneven wear pattern....just thinking
  • Dutchy Hoogen
    Dutchy Hoogen
    Is Harley the only place to get the ABS bearings? Because they are not cheap. Feel like ditching the ABS myself.
  • Dutchy Hoogen
    Dutchy Hoogen
    Thanks Chinashop bull.
