engine revs drop slowly, bad cold starts
  • Mr.Mow
    Mr.Mow
    I have my new wideglide, VH slip ons, S&S AC and VH Fuel pack 3.
    Ive downloaded the correct map, its been auto tuning for a week and runs pretty well...
    But, im noticing as I approach a red light or brake hard for a corner when the revs are hitting 1800 or so its holding them, theres a slight surge (disconcerting coming into a corner) or even as you come to a stop at the lights the engine revs along ahppily at 1200rpm for a bit before slowly dropping to idle.
    The other end of that, starting cold... terrible hesitation at really low rev settings, stumbles and stalls.
    Any advice? I know one of the mufflers is leaking a tiny bit (some pops on decel) but I'm not sure thats the problem.
  • robots
    robots
    can you compare the original map to the new one? look for significant differences
    with the cold start, hesitation, stumble & stall look at IAC steps and bit more fuel
  • Adrian1200CA
    Adrian1200CA
    Had a similar problem with mine, ended up being the TPS had been damaged. Yours could just be the leaking exhaust so I would fix that first especially if u have been auto tuning with the leak. If so go back to the std map and fix the leak. Advice from V&H was to run at least 2 tanks of fuel after repairs b4 auto tuning again.
    Assume u are running 98fuel?
  • Mr.Mow
    Mr.Mow
    well I reverted back to the standard "VH 3" slip on + Aircleaner map"..
    Didnt even think to do that, seems the auto tune had put the map so out of whack, bike seems much nicer now.. good thinking guys!
