Online: Retroman
Lights upgrade, information please.
  • sixthsense
    sixthsense
    Hello All,
    I am looking at upgrading the lights. My requirement is change the stock yellow light of number plate to White LED and Front head light to White LED. Can this mod be done? if so is this just replacing the bulb or complete head light and number plate unit? I tried JP cycles and Revzilla. Cant figure our how I can I do this. Any help is much appriciated.        Cheers,
    Ajay
  • noctm
    noctm
    I replaced the bulbs in my headlight no dramas, it's just the main bulb and park bulb similar to older car lights, H4 I think the main bulb was. Couldn't source any LED bulbs though, but I did fit some brighter and much whiter bulbs that satisfied me.
    Not sure about the rear assembly though, looked sealed to me last time I had a quick squiz but I've removed that whole assembly from my bike anyway and use LED bolts/screws on my plate. Can find em cheap on ebay and they're sleek enough and do a good job.
  • sixthsense
    sixthsense
    Thank you!!  I have my first service due in 2 weeks time. I will check with HD that time for white light H4's that time.
    Thankss again!!
    Cheers,
    Ajay
