Online: obisteve, John.R
Central Coast Harley
  • Winger
    Winger
    Any forum members residing in the Gosford area willing to check out a bike at Central Coast Harley? If anyone interested , please pm me and i can let you know which bike Im interested in.  While I'm at it, has anyone got any advice or had any bad experiences buying interstate?Cheers, Winger.
  • FLIPDOG
    FLIPDOG
    some states will require a blue slip to change interstate regos over
    this will mean no aftermarket pipes or breathers, must be factory stock
    check out your states requirement on this first to save any shitfight or inconvenience that may rise
    if the bike is less than 5yrs old you may not need to do this but not 100% on that, id check it all out
  • Speedy
    Speedy
    Probably same deal, if a rider moves interstate and is then required to change rego to ( new ) home state ?
    Newer vehicles require an Id inspection when transferring interstate. Even though it's not a road worthy examination which you get elsewhere, you can't take a non roadworthy bike thru the id inspection as they're not idiots.
    If the bikein Gosford is newish and has a warranty, that'd be some piece of mind
