Race tech gold valves
  • chopa
    chopa
    Went to install these tonight but when I pulled my forks apart i found someone had drilled extra rebound holes plus there was 3 rebound springs and there should only be 1 as per manual. Worst part is I don't know which one is the stock 1
  • chopa
    chopa
  • chopa
    chopa
    Thats what i thought. Don't understand why they had 3 springs and also can't work out why they would drill extra rebound holes. At the bottom they have been drilled the same way Racetech tell you to
  • chopa
    chopa
  • chopa
    chopa
    Hi Hilly it already has progressives in there now so going with them and the blue 40lb spring.
    Thanks for your help too
  • chopa
    chopa
    Always keen to learn more
  • chopa
    chopa
    Thanks Hilly I will give it a go and let you know how it ends up
  • chopa
    chopa
    Ok I now have it all back together but only got a to do a short ride and can already feel a difference especially on speed bumps. No more sharp jolt. Still maybe abit of fine tuning but will have to do a decent ride first. Thanks again for your advise Hilly
