Online: Kato
fuel tap/ petcock leak.
  • bobby bob
    bobby bob
    g'day fella's, fuel tap on my 87 softy has developed a leak and upon inspection i have found the flat o ring that sits in the base of the mesh filter has split, i have tryed without sucsess to find a replacement, goggled but no yoy, can only get complete new tap,Q.. does anyone know where i might get the correct flat oring from, thanks.
    Not the same seal bonkerz , new tap Bobby bob you may be able to get a Oem seal from a dealer that should work even if your running a aftermarket style tap It's a pain when the 3 window seal lets go in the tap too had that a few times
    Yeah, I just meant being fucked over by a tiny bit of rubber :)
    Try 62172-02 or Jims JGI-62172-75.
    They should fit a 22mm tap
