Online: Stuart
fuel cap leak
  • beehappier
    beehappier
    Hi guys. I have a 98 fatboy, and if I get a few fuel stains on the tank where it leaks from the right hand side cap.
    Obviously it is getting up a bit of pressure when the fuel get hot and blows off through the cap breather.
    Is there a simple fix for this?
    Thanks.
    Yep buy new cap orings from a dealer or a set of aftermarket new caps
  • beehappier
    beehappier
    Thanks. I hadn't thought of new caps.
    I have been doing my homework and it turns out that the aftermarket stretch tanks i have do not have an vent nipple.
    So there is no vent line or vapor valve. I thought that might be the source of the problem.
    I am considering putting a t piece in the crossover line and installing a vent line and vapor valve.
    It should stop any pressure build up, but I'd like a second opinon.
    Some people reckon it will leak fuel if the tanks are full and it is on its side stand.
    I figure if that happened it would happen with a normal vent line anyway.
  • Colstah
    Colstah
    Not sure if I'm reading you right, but if you put a T piece in the crossover line as you suggest, I think any pressure in the tank will just push out fuel. You need the vent to originate somewhere in the airspace.
    Someone who knows will probably chime in, but I guess there must be a faulty component somewhere and assume that they don't all do that. So Perthog is likely on the money with his new caps or O rings.
  • chopa
    chopa
    Just buy a vented fuel cap
  • beehappier
    beehappier
    It actually has a vented cap now and I think the fuel is leaking out of the vent in the cap when it gets hot and the pressure builds up.
    There is a crossover line that originates in the airspaces at the top of the tanks to balance the air pressure in both tanks. That is where i am thinking of putting the t piece. I'm hoping the pressure blows out the new vapor valve rather than the vent in the cap.
    Heres a pic.
    Thanks for the help guys.
