Online: GGUser744
Leather Panniers for 2013 Road King
  • patgreyling@hotmail.com
    When I fianally upgraded to a Tourer (2013 Road King) they at HD decided for a year or two that they would not offer the Leather Panniers (saddle bags) for the King and I had to go for hard panniers - no choice.  While the hard panniers are OK and functional I prefer the look of the leather ones.  MY QUESTION IS....can I get Leather Panniers now to fit the 2013 model?
  • Deadwood
    Deadwood
    Yep, they are interchangeable, so look for Road King Classic of the same year (or 2009 - 2013) and the will fit ...OR... you could swap with me! I'm looking for a set of hard panniers.
    Hi Mate, thanks for the reply... appreciate the offer to swap but as I have the Limited Addition Anniversary model I want to keep the original bits. Thanks for the help anyway.... cheers pat
  • Deadwood
    Deadwood
    Looking for extended hard bags myself. Check out eBay US motors, probably the cheapest option for OEM used gear unless you want brand new but I reckon brand new factory Road King Classic panniers would be expensive.
    Swap between you blokes would be sweet. Just an opinion but most people don't care about anniversary models as they come out every 5 years and aren't that special.
    Yes but I want to keep original colour paint job in case I ever sell her...
  • TJF60
    TJF60
    Gday I have some leather panniers from my 2009 Road King I live in Perth let me know if you are interested
