Push Rod Cover Tool
  • wildchild
    wildchild
    I am looking for a local supplier if any for a Push Rod cover tool like the Motion Pro version.
    Anybody know where to get one or similar?
    Flat blade screwdriver with thin rag around it so you don't scratch anything and leaver of cylinder head/ barrel fins
  • Daggs
    Daggs
    Yeah I wrap some electrical tape around the tip of a small flat blade screwdriver, works fine
    Screwdriver that has a square shaft does the trick for me.
    If you where adjusting pushrods on a daily or weekly basis the tool would have its place but a screw diver does the exact same thing if used with care
