Electroplater in NSW
  • Brett
    Brett
    Can anyone reccommend an electroplating buisness in NSW or ACT where I can get a few bit's chromed ? Maybe the wheels even . There's a couple in Vic that advertise in the mags but frieght may be an issue. cheers
  • Brett
    Brett
    Flan , I give up , can't see anyone advertising electroplating on the site , only polishing!
    Scull, Only guessing but I think they drop the part into a acid bath to clean em up.
  • hutch82
    hutch82
    May be look up fabricators or machinists as they also do that type of stuff...
  • sime69
    sime69
    The local HD stealer in Canberra recommends and uses Electroplating Technology in Queanbeyan for chroming. I have a friend who restores cars and he says they do good work too.
    I used Chrome World in Fyshwick ACT to get a stock wrinkle black HD speedo mount chromed, final result was pretty good but pricey (a new HD one is $195 and to chrome the stock one was $140).
    You don't need to remove paint etc. before chroming, they do all that for you. Apparently the cost escalates according to how 'fiddly' the item is, because of the final polishing. So I imagine a wheel would be fairly expensive. Also, Chrome World told me not every kind of metal can be plated, and some common HD alloy bits don't give a good result. They actually suggested looking at chrome aftermarket parts first, and if too dear then getting a quote from them.
    Sime
  • Jeffro
    Jeffro
    Mate try this number 0413 134 343.  I think this bloke does electroplating, crome, gold and other colours.  His name is Ferrett.
    Goodluck
  • Big Joe
    Big Joe
    Brett we use Astor Metal finishes for our pipes and other bits. They do a great job and warrant all their work for us.
  • imoo6170
    imoo6170
    i have also used Astor Metal  - found them to be very good quality, was a bit slow but given the quality I was still very happy.
  • imoo6170
    imoo6170
    Astor Metal Finishes contact details are:
    Contact - Richard Hammond
    93 Malta Street
    Villawood  NSW  2163
    (02) 9727-5622
    http://www.astormetalfinishes.com
  • Brett
    Brett
    Thanks fella's ,will get on the phone.
