Online: GGUser260, Hilly
Super tuner Calibration Error
  • BAKES
    BAKES
    Go to Workshop efi section and have a look at the SEPST for dummies, it might help you find where you are going wrong.
  • Retroman
    With the Supertuner pro latest edition , you have to update every 30 days or so or close to that. That is for the Supertuner software on your laptop
    And you have to update the firmware for the dongle as well I have found , quite often when the dongle has been used before.
  • Sparra
    Sparra
    Is this tuner one of your re-furbished ones???
