muffler outlet diameters
  • muph
    muph
    Greetings.....can anyone enlighten me as to why my 2007 fatboy has different outlet diameters on the oem mufflers??
    thanks
  • Retroman
    To do with the 'Euro 4" noise regs we get by default in Australia
    At certain road speeds / revs / gear the bike is actually a 2 into 1 system
    By now most 2007's will have had the system "tuned out" with one of the race tuners , and /or physically removed by the owner
    As soon as you fit any aftermarket exhaust it's gone anyways , both mufflers will have equal outlet diameter
    Is your bike a recent used yank import ? Even then , "Aussie mufflers" will have been used to get it complied and past state rego
    Even new bikes today still have that stupid system on them on most Softail and Dyna models
  • muph
    muph
    Ok peeps, I see the light now. Yes mine was first licenced in Oz. I just removed my V&H slip ons, just to loud for me. Found these OEM mufflers and fitted them a few weeks ago and just noticed the difference of the outlet diameters when cleaning the bike. Thanks for the replies. By the way, i seem to have more torque now. Before with the V&H mufflers the bike seemed to struggle some when going to 6th at anywhere between 80 and 90 but now no probs at all even at 80. Its quiet tho.
  • Retroman
    What you can do is source used Fatboy mufflers in the USA. 2007 to 2010 should do. 2007 Deuce had the same mufflers.
    Easy enough to find them on US eBay
    All other Softails the mufflers won't fit
    Back in 2007 most US states did not have catalytic converters in the mufflers ( yours do for sure , it will say Euro catalyst on them !)
    You'll have to do a part number search ( I used to know all the numbers but that was donkeys ago sorry !)
    Those mufflers are a bit "louder" than Aussie spec mufflers , and perform better to boot ,both same outlet diameter
  • muph
    muph
    Yes mine have cats. I wonder if anyone has tried to drill out the cats?
  • Hudson76
    Hudson76
    Mate just quietly I wouldn't be riding in 6th gear at 80 or 90........ unless you're talking MPH
  • muph
    muph
    Yep, I hear ya, I'm just making a comparison. The bible does say minimum speed for 6th is 80kph tho. I'm just trying to get my head around this increase in torque after fitting the OEM cat mufflers.
