Online: obisteve, Hilly
Long Ride Shields
  • graz
    graz
    Anyone tried the Long Ride Shields on a Rushmore streety yet? Pretty good prices so thinking of ordering a couple of different hieghts at the same time to try and save on postage. Also if you have which model?
  • slup
    slup
    Highly recomend them, got a 10 inch screen on my street glide with no issues dealing with them.
  • steelo
    steelo
    Tim should have half a dozen you could try out for size.
  • Hallze
    Hallze
    Hey Graz. I had a 7" Ultra on my '08 Streety for a while. It ended up breaking so I got a 10" Freedom screen. The Freedom screen is a lot thicker and sturdier than the Long Ride screen. It also costs a fair bit more too! Hope this helps mate.
  • mickle
    mickle
    There not worth 2 Bob.
  • graz
    graz
    Thanks fellas. Some good feedback and some bad.
  • mickle
    mickle
    I have tried both, Longrider and Freedom, hands down Freedom is a better quality product, I have a brand new Longrider make that 2 brand new
    Longrider shields sitting in the shed. The first shield they sent me had a 50cent piece size blemish in it so they replaced it at no cost to me other
    than waiting time (no quality check), in the meantime I read some reviews on the Freedom and decided to give them a go, so glad I did.
    Graz, have a look at baggershield too. Adjustable from 8 - 14 inches in seconds without tools for looks and touring comfort when you want to change between those two things. Got one on my road glide and very happy. Price good too
