Online: Soapbox2627
Suspension Setup
  • brettm357
    brettm357
    So i have Ohlins on the rear and racetech springs and emulators on the front (was going to change to catridges but trying to tune the emulators first) riding 2 up the bumps - manhole covers and usual sharp road bumps are smoother and better feeling - have the emulators at 3 turns with blue spring, 4 bleed holes drilled, 10wt oil racetech springs are 1.3 where should i start eg. are my springs too stiff i am 120kg and my partner 80kg
  • brettm357
    brettm357
    The 1.3 springs supplied by racetech were recommended by them for a 120 rider - the ride i get when i have a passenger is smooth as over ruts in road, concrete drain covers in road etc, but when im on me own i can feel every jolt - feels harsh
    Just want that smooth ride when im on me own
  • brettm357
    brettm357
    Bike raised 155 mm seal to triple tree
    Bike on ground no rider 135mm
    bike with rider 127mm
    I have 20mm of preload
  • brettm357
    brettm357
    Backing of blue spring 2 turns so ill only have 1 turn on emulator spring
    Compression or Rebound - i have been thinking compression because its when i hit the bump
    How do you tell ????
  • brettm357
    brettm357
    Rear with the ohlins is
    Bike raised 340mm
    Bike on ground no rider 336mm
    rider on bike 315mm
  • brettm357
    brettm357
    Is the rear settings not right ????
    yes drilled holes in damper rod
  • brettm357
    brettm357
    Ok - and thankyou for the help in advance
    With the bike raised i measure the rear from the fender to the axle 340mm
  • brettm357
    brettm357
    From what i have worked out from reading my rear maybe on the soft side as i have very little sag with bike only 4mm
    Preload rings are cranked about 3/4 of available  threads to get rider sag of 25mm
  • brettm357
    brettm357
    no they dont bottom out i did some heavy stops and best i could get it to move was 88mm
  • brettm357
    brettm357
    Would reducing fork preload on the current heavy spring give the same effect as leaving preload what it is now 20mm and replacing spring with softer one ????
  • locks
    locks
    Not exactly, the spring rate won't change on a single rate spring, you may get away with that spring if you can fine tune around it or it might be just too much for your taste, ride is a personal thing, some like it softer than others, I aim for plush but firm and use oil volume to control dive rate in the last part of the stroke, I don't know everything about it just what I've learnt from doing my own bikes in the past.
  • brettm357
    brettm357
    Ok ill reduce preload untill i get 32mm of sag - test ride then i not good ill reduce emulator preload by 1 turn
    if i need new spring what should i get
    also does increasing fork oil level aid in reducing brake dive
    my level in 130mm
  • brettm357
    brettm357
    Forget the question about the spring checked calculator on racetech 1.2 also did the valving search which gives me an oil level of 150mm
    Mine is 130mm having the level that i have will it just stiffen the last part of fork travel
  • brettm357
    brettm357
    Hilly,
    Did you set fork oil level to use most of available fork travel
    Did you drill additional bleed holes in the emulator
    If racetech recommends 1.2 spring for me do i go with that or are thw racetech calculators on the stiff side
  • brettm357
    brettm357
    Feels very firm hand on brake pushing hard maybe 30 - 40 mm travel hard to know don't know what they are suppose to feel like - first Harley I have owned
  • brettm357
    brettm357
    You mean ride and hit front brake hard ????
  • brettm357
    brettm357
    Changing preload this afternoon to tune sag - did some heavy stops braking etc and was getting 88mm travel forks have total travel of 120mm
  • brettm357
    brettm357
    Just a quick rebound question based on comment made earlier - when i push down on centre of bars the bike comes up to a stop - but if i hold the front brake and push down when it comes back up it bounces (pogo) before stopping - which one is the correct test
  • brettm357
    brettm357
    OK - been reading the suspension bible suggested to understand everything better - the sag im about to setup to clarify the fork setup the bible mentions 30% of fork travel - Is the fork travel measurment the one with the fork caps off and forks compressed so 120mm or is the fork travel the max i can get the fork to travel under heavy stop 88mm
    40mm sag or 29.3mm sag
    where does the 32mm recommended setting come from ????
  • brettm357
    brettm357
    ok reduced preload to 12mm this gave me
    155mm bike on lift
    130mm bike on ground
    123mm bike on ground with rider
    32mm of sag
