Online: beaglebasher
Rear Guard Options for 87 Evo softail.
  • Phredd
    Phredd
    Trying to workout the best options for replacement rear guard on the 87 Softy.
    Looking for something that follows the wheel around rather than kicking up like the standard one. - See Image.
    I have been suggested that the front Heritage guard would work with mods, or maybe a custom offering. If you know a standard guard that might fit then model details would be appreciated.
    I need to buy this sight unseen, and without trialing, so if you have already experianced this it would save me buying a seletion of guards that don't fit.
    If thats your Bike you have to Lower it, Thats the fix not the Fender
    Agree with walka and dave in regards to lowering it but that's not the bike that's a tc. He's got a evo maybe you should look into
    What one of the other boys did sdmf I think cut and shut with a bit of extension to it it look great if that's the look your after
  • Independant_84
    Independant_84
    Don't you blokes go around corners. Worst thing I ever did was lower my bike .It looked good but I like taking corners a little faster then pedestrians in a retirement village.
  • Wimbo
    Wimbo
    No probs going round corners on my 83 Softy
    Scrape boot heels abit but thats all.
    Check the rear guard bro, maybe thats the style you want.
    Those mirrors were just an interim thing btw.angel
