rattle
  • wayylander
    wayylander
    i have a nightrain and it has a rattle when i back off.... sounds like a chain hitting in primary case.....just read the threadds about a rattle on the left side and they are all while underr power.....any help gratfully appreciated...
    Sounds like a primary chain
  • bobby bob
    bobby bob
    you could pop the inspection plate and have a look, then adjust chain if needed.
