Online: Stuart
No category for fxr bikes?! Then are not a softail, dyna, touring, classic or custom. So where do th
  • Bennyd04_87
    Bennyd04_87
  • Bennyd04_87
    Bennyd04_87
    As the subject line says, where do the fxr series bike fit in?
    Early dyna
    They're like between a Dyna and a Sportster, but I think the "real" Dynas replaced this bike. If we don't have an "Other bikes" forum then I'd go with Dyna.
    Sorry Benny, I think that means you cannot use this forum haha
  • wazdog
    wazdog
    Obviously requires a new section called Best Ever Harley
  • Bennyd04_87
    Bennyd04_87
    Dyna people call them a sportster. Sportster people call them a dyna
    Softail and touring riders have no clue what they are. And fxr owners call them the best bike ever.
    Still doesn't give them a section on this forum haha.
  • Soapbox2627
    Soapbox2627
    here we go, the forum will bend for the minority, after all that is said and done
    they come in and want to take over
    why cant they just go with the Aussie way, no we have to change wink
    You'd have to be a dick to call it sportster seeing it's got a big twin in it
  • Daggs
    Daggs
    They were superseded by the Dyna ....so.... Obviously Dyna....
  • Wimbo
    Wimbo
    Dyna Sports.
  • Sparra
    Sparra
    There only a fanny hair out of the Classic section....
  • Bennyd04_87
    Bennyd04_87
    Perhaps we get free roam. Classic dyna sportster special. Add bags and screen for tourer section even? ??
  • Darrin
    Darrin
    I am biased because I own a 1992 FXR! I also still have the notes about the difference between an FXR and Dyna in my phone (notes section!), as I bought it 6 years ago, so I can cut and paste a bit to ask: Are we really talking the same thing at all, FXR to Dyna? Give it its own section! Everyone of course knows that the FXR handles better, as it was designed to have a higher seat position, greater lean angle, and stiffer frame. Everyone also knows the Dyna frame was cheaper to produce and so replaced the FXR.
    Less well know are some of the build-related differences that just make FXR to Dyna like apples to oranges. Top of the list has to be that instead of heavy castings, the FXR frame has a lot of hand-welded stamped-steel parts. That triangular central frame design, which for aesthetic reasons they hid behind chrome guards, signals the frame incorporates superior geometry (triangles are super strong structurally!).
    It's no coincidence an FXR out-performs a Dyna. The FXR has a full frame, versus the Dyna which uses the transmission to make up part of its framework. The FXR frame is stiffer, with better lean angles, lower centre of gravity and neutral balance. The FXR runs three rubber engine mounts linked to the frame so that it's like it's running on rails, versus the Dyna two rubber motor mounts allowing for sideways movement of the engine. The FXR swing arm is mounted on the rear of the gearbox with two stabilizer units, versus the Dyna swing arm 'floating' and connecting at the transmission case not the frame (and with one stabilizer), giving you the flex and wallow of the Dyna.
    who cares about FXR's   next they will be asking for a forum page on Harley Toppers
    I hope you have a steel trace on that line there Ian. Ha!
  • chopa
    chopa
    For fuck sake you've made 11 post and already whinging.
    Just put it in with the Dyna
    What the hell is a Dyna? Is that the cheap inferior replacement for the FXR; the poor buggers!
  • DAVUTCH
    DAVUTCH
    So what are you saying a dynas not a mans bike for fucks sake really
  • boxa
    boxa
    See there ya go ,, Fucking minorities  coming in and demanding a change  Dynas not good enough for them , they want there own section now , Telling ya , give them another year or so and they will be demanding we all chip in and pay for there forum t shirts .. cool
