New member - 120ci street bob
  • DJP_120ci
    DJP_120ci
    Hey guys, just a quick introduction. 25 years old from country South oz
    Recently bought my first Harley, 2011 denim black street Bob running a R&R 120ci kit plus much more.
    a few changes have been made since the pictures before I bought it and since I have owned it, a keen eye will pick them.
    I also have new fork sliders and triple trees waiting to be powdered black to finish the front end off.
    Welcome mate
  • Wimbo
    Wimbo
    Welcome mate.
  • Krackers60
    Krackers60
    Welcome to the Forum.
  • Winger
    Winger
    Welcome bloke.
    Welcome mate , keep an eye on the SA Rides section , we do quite a few country rides .
  • DJP_120ci
    DJP_120ci
    Thanks for the welcome guys!
    Tim I will keep an eye on the SA rides for sure! FIFO roster will make it hard but I'd be keen to get to whatever I can.
    The bike was purchased in Adelaide so a few boys from that way may have crossed paths with it over the years!
  • Daggs
    Daggs
    Welcome mate, sweet bike, I'm down in the south east, where are you?
  • Odin
    Odin
    welcome, not bad for a 1st Harley with a 120ci. enjoy riding
  • DJP_120ci
    DJP_120ci
    Daggs I'm based on the eyre peninsula, Whyalla to be exact.
    Thanks Odin, I'm more than impressed with it! I didn't get any dyno sheets with it, but word from the guy that built it is around 130-140 hp
    Go hard or go home don't they say??
    Shiny side up boys!
  • Daggs
    Daggs
    That's my motto too mate lol
  • DJP_120ci
    DJP_120ci
    Thought I might give a quick run down on the bike and add a few pictures
    I'm not sure on all the specifics of everything but I will do the best I can!
    Started life as stock 96" now running
    R&R cycles 120" challenger engine package (rrcycles.com) compression set to 11:1
    Welded and balanced crank
    S&S 625 gear drive cams
    HPI 55mm throttle body, upgraded injectors and RSD air intake
    Thunder max efi ignition
    Build and tuned at Ray's cycle shack in Adelaide
    Ohlins shocks on the back and a progressive spring kit in the front
    Rear fender has had the tail light removed and incorporated in the LED indicators
    As well as an assortment of Bling bits on the bike
    I can't seem to add pictures so I will edit my first post and add a few more to that!
    Stay safe
  • Far Canal
    Far Canal
    Welcome. Kick arse first Harley there mate! Take care on the beast.
    Welcome, starting small I see, lol
  • Ric
    Ric
    Welcome mate
    That's a nice looking bike for sure, plenty of "get up and go" I'll bet.
  • DJP_120ci
    DJP_120ci
    Thanks guys,
    More than enough poke for me at the moment.
    Just need to get comfortable getting her over around the corners, guess that just means a bit more time in the saddle.
  • ralphski
    ralphski
    welcome, and nice ride....
  • 06 Softail
    06 Softail
    Welcome.  Nice ride, sounds like a bit of a ball tearer you have there.
