Online: Stuart
07 fatboy clutch
  • Fat Tom
    Fat Tom
    hi all, hoping I can get some advise re: my 07 spec fatboy clutch adjustment.
    Have removed derby cover and am attempting to release the lock nut to adjust my clutch
    and I cannot budge the lock nut. I have got to the stage where the nut is partly rounded and
    have now stopped. Any comments to help me fix would be much appreciated
    thanks in advance
    Fat Tom
  • markwoumla
    markwoumla
    Mate , it should'nt be that tight in the first place.. Use an 11/16th offset wrench, (I think this is your size , but check), Anyway,, have the bike in gear,, tie down the rear brake ,, so the clutch pack can't rotate, while breaking and tightning the lock nut.. As your lock nut seems very tight, give it a spary with wd40, and let it sit for awhile.. As you will probably replace the locknut anyway, (part no, 7848w), get a large flat screwdriver , and give  it a few light taps with a rubber hammer on the flats of locknut in an anticlock wise direction... Now get the offset wrench and give the end a good bump with the palm of your hand..  See how you go ....https://www.youtube.com/watch?v=WgWn3osUMNo
    Some how I don't think it would need wd40 seeing it lives in oil / oil mist
    And as it's super tight it might be easer to pop the circlip and pull the plate and hold it in a vice than refit you may get away with just flipping the nut depending how bad it is  if not any fastner shop will have one
  • Fat Tom
    Fat Tom
    thanks guys, will give it another go and let you know how I get on. Fuck knows how it got to be so tight, I bought bike second hand with 24k on the clock
    so whoever played with it before has over tightened.
    Yep, pull the circlip !
  • Daggs
    Daggs
    Use a socket (deep socket if needed) and long breaker bar rather than a wrench
