Online: B0nes
Fat Bob seat on Street Bob.
  • svturtle
    svturtle
    Looking to buy a near new stock Fat Bob seat from an 2015 model to put on my 2016 Street Bob.
    Part number is H842201AR13594
    Is this a direct fit?
    Dunno mate but a second hand one will pop up no doubt
  • robots
    robots
    Check the HD catalog for a seat like the Badlander and will tell you if it fits all 06 up dyna or you need a different one for the street bob and fat bob
  • svturtle
    svturtle
    Thanks guy's, just did what i should have done first, researched! and yes it will fit.
    I'm buying one off Gumtree tomorrow fatbat, didn't want the guy to hold for me if didn't fit.
  • robots
    robots
    Good stuff, make sure its got mounting tab at rear of seat, and you should get the rubber squares to put on fender
  • robots
    robots
    any pics of the new fat bob yet speedy?
  • Speedy
    Speedy
    Freedom pipes due tomorrow.
    Probably find difficulty in sleeping tonight.
    Will try for a vid when new pipes fitted.
    ( so little on the net re: Freedom / Fxdf )
  • robots
    robots
    thats great, good luck with it
