Online: wildchild
Black out front forks
  • AlHD48
    AlHD48
    Hi All
    I am interested in blackening out my front forks on my sportster , has anyone out there done this ? how did you do it ?
    I looked up prices and fuond that RSD was a joke asking for $180 AUD for hollow metal covers.
    is it possible to black chrome the fork legs or will this scratch away ?
  • brash
    brash
    Vinyl wrap, if you don't like it piss it off.
  • AlHD48
    AlHD48
    Hi Brash
    thought about it but want a permanent change.
    im looking into making some , can't be too hard , just hollow aluminum pipe and powder coat it gloss black
  • Independant_84
    Independant_84
    Checkout
    http://www.tnk.it/en/prodotti5.php?cat=FORK%20TUBES
  • AlHD48
    AlHD48
    Thanks for the info gents .
    Independant 84 i think those for tubes are for sports bikes and they are the outer part of the tube , so it wont scratch .
    on the sportys the fork tube goes into the lower fork casing , which might make it scratch, correct me if I am wrong
    apparently DLC coating is the way to go
  • AlHD48
    AlHD48
    found it in the states
    http://toplinetubes.com/
    I recommend any coating is going to scratch over time. If the tubes are coated they will need to be sized right so that the OD remains the same as the units they are replacing. It all seems to be a LOT of work for very little return.
  • Howard
    Howard
    Hi mate, I presume you are talking about the fork external legs. Why not just get them painted or powder coated?
  • BAKES
    BAKES
    I got mine powder coated
  • AlHD48
    AlHD48
    not the external , they are already black , im talking about internal tubes. in the states they are Dimond like coating, stronger and harder than chrome .
    looks pretty awesome
  • Howard
    Howard
    Hi mate,
    How do RSD covers work, can't follow how do the fork legs take them? The black tubes do look good but shit a fair bit of work, why not just put black gaiters on and vinyl rap the top bit or go to a wreckers and find some upside down forks of a GSXR or something that has black (or Gold) legs and sliders, seen one done on this site somewhere, sorry can't find it but looked awseome (his were off an R1 I think). Probably cost a bit more but at least you get decent suspension as well?
    Cheers,
    Howard
  • AlHD48
    AlHD48
    very true Howard , I was going to put progression mono shock cartridges in them . I might look into the sports bike suspension as an upgrade , might take a bit of modifications to fit on on i think
  • Howard
    Howard
    Tried again to find the link bu still can't. He reckoned it was pretty straightforward and cost effective. I'll try again tonight, have a feeling I posted and he posted some details back.
    Cheers,
    Howard
  • Howard
    Howard
    Hi mate found it,
    http://www.hdforums.com.au/Default.aspx?tabid=71&forumid=1&tpage=107&view=topic&postid=108446#630999
    Its from Pil on page 107, go to his Pics, Black forks bit silver sliders at the bottom. I'm sure some GSXRs had the black finish, so if you can fit R1 forks you should be able to fit GSXRs. Know you can as when looking for mine a guy over her was selling one with GSXR forks but wanted more than I could afford.
    Cheers,
    Howard
