Online: Stinga
103 street bob
  • jon doe
    jon doe
    any one out there got any idears.. i had new lifterd fitted o my 103  with 254E cam .. and the front cylender created a lifter tap after 2000k or les .. i loosened the push rods tubes aand wobbled the top of the push rod andthe rocker arm seemed to have to much end float . motor only done 23500ks about 5000 with the 103 upgrade .. i cranked it over holding the inlet puh rod and could feel a click in it .. any idears would help or have i chewed out more lifters.. i put B lifters back in asmine is an 09  bob ... thanks J.D.
  • jon doe
    jon doe
    Yeh hilly quick fit
  • robots
    robots
    get some stock push rods for it
  • jon doe
    jon doe
    robots ..its got 254E cams ..
  • robots
    robots
    there a few SE cams that can use Original Equipment Length, the 254E is one of those (see SE catalog)
    I ran the stock push rods with the 254E cam in my bike for a while, all fine
  • jon doe
    jon doe
    Hilly..... Google says 2 1/2 turns from zero. How much extra .. One or two flats ?? Or lock them up and back off till they spinn. That was S&S way to do it I think ........ They are stock lifters ... B. Read C's restricted the oil to the top , and in my opinion. The oil helps cool so it's needed. .?
  • jon doe
    jon doe
    Kool. But got one problem. Think they were cut but I'll check. The bits I got back ...... How do you like the 254E and what horse power torqu did you get ... ..
  • Daggs
    Daggs
    Don't use stock pushrods
  • robots
    robots
    You get a genuine 5hp, take to an Indy dyno tuner and fluff it up another 5hp for you
    Will run better
  • jon doe
    jon doe
    Mine got 102hp and 110 tq at rear wheels.  Just wondering what others got. When was stock with race tuner pipes and air cleaner had 77 but that's normal I think.
  • robots
    robots
    Good effort john doe
  • jon doe
    jon doe
    Robots .. What do they normally get with that cam??  Maybe they printed some one else's dyna sheet off ...lol.
  • robots
    robots
    Tell me bit more about your bike, I run details through my calculator
  • jon doe
    jon doe
    In boxes robots
  • jon doe
    jon doe
    In boxes robots
  • jon doe
    jon doe
    nice numbers daggs . a friend had a 106 with the same cams .. it flew
  • jon doe
    jon doe
    Adjusted front to 3 turns from zero , no clack but sounds like dead lifter. Faint rattle. Had a clack to start .. Could it me full synthetic oil ?? Mobil 1 HD
  • jon doe
    jon doe
    Done tree turns on front push rods seem OK so far I'll do front tomorrow. .. Thanks too.
  • jon doe
    jon doe
  • jon doe
    jon doe
    Hilly There's JOHNSON B 2313 lifters. They say there the original Harley B lifter ..from the states ... I hunted for the last of the B's one from here and three from there for mine the first time.
