Electrical mayhem.......
  • Rich2wd
    Rich2wd
    Hey fella's, I hope someone can help....  I have swapped the handle bars on my 2005 Softail Standard for 16" apes, because of this I had to splice in 250mm extensions to the handle bar switch block looms.   I have triple checked my wiring, soldered joins & heat shrink and all apprears to be good but when I turn on the ignition the front indicators light up (constant) as well as flash for a number of times.  Any ideas?  Pulling my hair out here.
    Cheers Rich
  • Drac
    Drac
    Have seen this before and some of the wires were mixed up at the plugs.
    Did you remove the pins from the plug housings?
  • Rich2wd
    Rich2wd
    Thanks for replies Drac & S.D.M.F.
    All fixed.  You hit the nail on the head S.D.M.F.  yep an import.  As I had to relocate the indicators from handle bars to the forks due to swapping to apes I shortened up the indicator looms.  The loom part I threw away had the third wire cut in it FFS....  Live and learn.
    Cheers Rich
