Which highway pegs
    Got myself some fairing lowers which are good but they limit how far forward you can rest your feet on the boards.  So looking at highway pegs and there are a few different types available.
    The crash bars are a fair way forward and although my legs could reach that far, I don't want my legs stretched out that far.  Maybe some pegs that will allow me to have my heels on the boards but my feet splayed out so that the top of my foot is resting on a peg would work. Or if my heals fitted on a highway peg with legs partially bent; that would work too.
    What are you other blokes using?  I see that Harley has a long angled highway peg, a short angled option and a 360 adjustable option.  So far i was leaning toward the short angled option which I thought would suit my height (6'1";). Also open to other manufacturers like Kuryakyn if anyone can recommend ideas please.
  • steelo
    steelo
    Hi there.
    Have a look at these on Gumtree $50, allows pegs to come closer to you. Just buy pegs. South Australia
    My set up . All H-D . I can rest my heel on footboard and foot on highway peg . Used my rear pegs as I installed rear footboards .
  • graz
    graz
    +1. Heel on footboard and rest on the highway peg. All HD parts and adjustable in most directions.
    Thanks eelo and Tim.
    Tim, which Harley part is that?
  • Tat2_u
    Tat2_u
    Tim you wouldn't have a part number for the Brackets by any chance ?
    Thanks too Graz. Keen for part number too
    Pretty sure Graz' s pic part no. is 50964-98 , chrome bolts to suit , 94140-02 .
    Check on this though before ordering .
  • steelo
    steelo
    Tims Harley highway pegs are more substantial and look the business.
    The ones I saw are Kuryakin on Gumtree "Harley Gear"
    Ad ID 1089579196
    Thanks hutcho. I went to the dealer today and ordered the short angle ones that Tim has above. Will attach the most basic rubber peg that Harley sells to them. All up about $190. As dealer didn't have any in stock to look at, they were kind enough to say if the short angle ones don't fit they will let me swap for the long or 360 adjustable ones
    Hutch did you see that deadwood is wanting to swap his black sissy for a chrome one. You still wanting a black one for tigger?
    Oh yep found it? Yep, a black one I need when one comes along. But the longer one. I don't have any ATM.
    Sorry I'm talking about the bracket that the peg attaches to. That is the same as yours Tim.
