Motul oils
  • jim76
    jim76
    Im looking into Motul engine oils does any one use them? if so how have u found them? im running a motul oil in the primary/gearbox at the moment. was looking at the 7100 20w50 to run in the sportser im running a 15w40 oil at the moment the top end sounds a bit rattly noise isnt getting worse so i dont think there is any dramas there.i dont want this to turn into a which oil is better just after your info n experiance thanks
  • Peter
    Peter
    I used Motul in the old Katana for a while but I could always smell oil and it developed minor oil leaks, I swapped back to Shell at the time and everything was ok. It has always put me off using Motul.
  • jim76
    jim76
    thanks for your responses, peter how many kms where on your katana n what motul oil did u use if u can remember?
  • Peter
    Peter
    I think it had about 40,000km on it and it was 20w50 part synthetic designed for air cooled big fours. It didn't use any oil but I could always smell oil and like I said it just weeped a little until I changed to shell. Very strange, but I have mates that swear by it ??
  • shadowhand
    shadowhand
    There's no drama with Motul oils. There synthetic oils are some of the best, I've read.
    I've just tested Penrite SIN 25 in the Twin Cam. SIN 25 gives my bike more horsepower and it cools the motor down to 75 degrees. The clutch doesn't slip. All round I like this for a synthetic.
