battery capacity
  • Odin
    Odin
    OK Guys, what is the battery capacity ( eg amps ) of a HD AGM Battery for a 2009 Fatboy. dont need to know the CCA.
    Odin
    I've found the best agm batteries to be so far are ssb with the most cca 420/450 by memory And Oem Harley in second but could never find out what the cca was and found gray dekers shit in my expernce ,the ssb look exactly the same on the
    Case without the hd logo apperantly dekers are made by the same company as the Oem but I don't think so the Oem
    Battery's I've had far exceed the dekers performance I've had and friends have had another one I haven't tried is redline battery's thay look the same as the ssb and Oem case in the pics but cheaper again but when I last needed one thay didn't
    Have any in stock So swaped from deker back to a ssb when I'm rich one day I might lash out and by a ssb lithium 700cca if any of my bikes need more cca
    softy and Dyna - 19 Ah
  • Independant_84
    Independant_84
    I found ssb was great had one for years no trickle charger it never let me down would have recommended them to anyone . Until I went down a rough corrugated road and it internally shorted and went dead flat on a 40 degree day . Luckily I only had to push the bike about 600 meters to swap batteries out. Apparently they are not very strong structurally.
