Online: B0nes, snoozy
'03 Dyna Super questions.
  • Roo Ted
    Roo Ted
    G'day all, I'm new to the forum.
    I just offloaded an '06 Custom Sporty and slipped into the '03 Dyna Super. I can't ride the Dyna like the Sporty, the forks bottom out at the touch of the front brakes. So do I just run some heavier weight oil in the forks or am I wasting my time? If I'm better off dropping some progressives in can someone suggest a decent brand and a supplier, I'm happy to do the work.
    While we're at it, anyone got a set of reduced reach controls for this machine?
    Oh, and I'm after a set of factory mirrors..........
    Cheers all and thanks in advance. Looks like a great forum here, I might stick around.
    Roo Ted.
  • 78gold
    78gold
    Mate,
    I put Progressives front with a fork brace and have found it much better than before.
    Also put progressives on back (930's) better than stock but not as happy with them, should have gone with something a bit better, $ were an issue at the time.
    Front is now very stable and even two up doesn't dive too much under braking.
    Ride Safe
  • Roo Ted
    Roo Ted
    Thanks 78gold,
    I was expecting to have to fit progressives. Was there a particular brand you used?  Where did you get them?
    Cheers, Roo.
  • DAVUTCH
    DAVUTCH
    Put in progressive springs and heavier oil made world of difference mate do it
    I have a set of chrome mirrors
  • 78gold
    78gold
    Mine were made by progressive springs (Brand Name) and I got them in from the USA.
    The fork brace made a difference as well and was fitted after the springs were done.
    Probably go with Ricors or Hagon shocks for rears if doing it again.
  • Roo Ted
    Roo Ted
    Thanks gents, much appreciated. Cheers!
    Roo.
