sofftail std 07 brake lights not working? need help!
  • 07fxst
    07fxst
  • 07fxst
    07fxst
    Park light is on, indicators work, but hand and foot brake does not illuminate brake
  • chopa
    chopa
    Maybe just a globe
  • bobby bob
    bobby bob
    Yes, go to the obvious and easiest place first.
  • 07fxst
    07fxst
    Globe looked fine, changed it anyway and still nothing, put a volt meter on the rear brake light switch wires and they were ok but nothing when i apply the both brakes, so i removed wires from rear brake switch and joined the circuit manually and now i get a constant brake light, so ill go replace the rear brake light switch. Fingers crossed
  • markwoumla
    markwoumla
    There was a replacement recall, for the rear brake light switch on certain models and years ... Looks like after your troubleshooting , you have found the problem..
    So why is it only the rear switch when the front brake lever isn't making the light come on ether ? Two stuffed switches at once don't think so two different circuits that achieve the same thing
  • 07fxst
    07fxst
    Thats what i thought perth hog, unless the front has to travel through the rear brake switch? Im gonna take it to the mechanics some time this week.
    When you disconnect the wires to the rear switch ,does the light light up with front brake than if does maybe it is a stuffed rear switch ,maybe it's shortening to earth than back feeding
    And causing both to not work Strange how neither are working though
  • 07fxst
    07fxst
    No front brake still even when i disconnect the wires from rear brake switch, ìll try replace the starter/brake light/fuel pump relay before i take it to the mechanics
  • Ando
    Ando
    Had same issue on 08 softy just changed switch under frame that wires plug into and works of brake hydralics
  • 07fxst
    07fxst
    Got my bike back from the dealer, turns out both front and rear brake switches needed replacing. So my brake light works now but now i have a very sensitive front brake light which causes it to flicker when i rest my fingers on the lever!! F*@k sake...
  • beaglebasher
    beaglebasher
    I had to replace the rear brake switch on an 02 fatboy (my local mechanic figured it out)
    I think it might be a common problem
    I haven't had any problems with the front brake yet but where is the front brake hydraulic/electric thing?
  • 07fxst
    07fxst
    Had a better look, and my lever after being squeezed wasnt retracting all the way back out, bit of wd40 and all good now, thanks for all your help guys. Much appreciated
