Online: John.R
VnH Big shots on 2015 street bob ??
  • Ted
    Ted
    Half way thru installing my new Vance n Hines Bigshots , noticed there is a cable with nowhere to install on the new pipes.. came from a spring loaded valve on the original pipes .. where to from here ?? what do i do with the cable .. will it affect anything if its not connected ? not far off install of a FP3 Tuner and V02 Air cleaner.
  • Ted
    Ted
    Thanks for the quick response guys ..lol Worked out that the 'Active exhaust control valve' cable and system is not required on the big shots, spoke with HD Service Manager at RHD in Tassie, they tell me I can remove the whole unit, and it will just give me a fault code. They will be able to remove the fault at service. Sounds like a bit of mucking around removing the unit, but should solve my issue..
  • Ted
    Ted
    Thanks FatfatBob , yeah understand that .. new to this Forums thing , and just have parts laying everywhere in the shed and want to ride .. Search function u say .. ok , will get onto it .. cheers Ted
