Sticky rubber hand grips anyway to fix them.
  • Choco
    Choco
    G'day an age old problem that many of us suffer sticky rubber on the hand grips. Now I know a few of you would say just replace them but I really like the grips on my bike they are a aftermarket set and only about a year old.
    So anyone found a cleaning agent that works on these sticky hand grips I have tried soapy water it helped but didn't fix the problem so I am open to idea's cheers.
  • Choco
    Choco
    Ok thanks for your replies cheers.
