Online: Lushy
Vrod number plate holder
  • Draino
    Draino
    This may of been beaten to death down the track somewhere, I know you can get something like the knight industries fender eliminator with the led indicators in them but they are illegal.  Can I get just a number plate mount that eliminates the extended black plastic fender on my 2014 nrs and still run the factory rear indicators?
  • Knight
    Knight
    Yes you can run a daytime running light in my fender eliminator or nothing at all. The number plate brackets bolt on/off if you want to run a side plate, or if ur really keen to smarten up the rear I have put together a shorty fender.
  • Knight
    Knight
  • Draino
    Draino
    No thanks
  • catman
    catman
    Draino
    I got one off eBay out of Europe , it was pricey at about $195 it is made out of steel and mounts to the original holes under the guard , it has a led for the number plate light.
    Check out v rod on eBay .com.au
