Online: tussuck
96 sporty front rim
  • Sporty
    Sporty
    hi there, just wanting to change my front rim from the standard 21inch to 19inch, has anyone done this, and if so are there benefits/detriments? Any advice would be appreciated. Cheers
    what model do you have sounds like a custom with da 21" front wheel , 19" is a better choice for sure easy swap or relace, if you got a custom better to have da normal lenght suspension f/r better ground clearance & better on da bumps
  • Sporty
    Sporty
    It's a 96 model, ok need to find a rim like this one to swap, or try and buy another to replace. Thanks for the advice daddyracer56
    i have a 19" here but it has 2 little rust spots on da rim were da water hangs
  • Sporty
    Sporty
    Have you got a pic?..
    i don't know how to do a pic , ive never owned a mobile ph, are you in Sydney ?
  • Sporty
    Sporty
    Yes I am. I can come have a look if you in Sydney as well?
    i sent you a pm message did you recieved it
