Online: John.R
wider rims for street bob?
  • Daggs
    Daggs
    You may have to relocate rear indicator wiring as the 200 can chew it, you may also have to play around with spacers to get the wheel perfectly centred as there is only about 3-4mm side clearance from tyre to guard. Also belt pulley may have to be spaced over away from the tyre a bit.
    I have done all these things, have been running a 200 on mine for about 7 years. Looks and handles great
