Online: tussuck
Engine Upgrade
  • KOSTO
    KOSTO
    Hi All,
    Just joined HD Forum.  I have a 2015 Street Glide Special.  Got Vance and Hines power duals and SE slipons. The bike runs great and has heaps of grunt.  Would love to get a few more horses out of it.  Considering either a Stage 4 kit (for warranty purposes) or let Eastern Big Twin play with it.  Any suggestions for Stage 4 equivelant or better?????
  • KOSTO
    KOSTO
    Grunt off the bottom and midrange.  Strong to 4500
  • markwoumla
    markwoumla
    Looks like ya have the performance bug good and proper KOSTO !!!!
    Personally ,, with a nice bike that you have , and not a lot of coin,, with a good set of cams to suite,, installed and tuned by a mob like EBT ,, you should be satisfied,, But, But, if the bug has you totally by the balls , then good luck,, and enjoy the journey !!!!
    Good set of cams installed and dyno tuned you'll get what you want. Never heard a bad thing about ebt
  • KOSTO
    KOSTO
    Thanks guys, will go and see EBT and post the results. Cheers
  • Daggs
    Daggs
    Do some head work too mate if you can stretch the coin that far
