Online: B0nes, Wanderer57
No Spark
  • Independant_84
    Independant_84
    You could download a manual Get a multimeter and go through the test procedure .It could be as simple as a broken wire It's always a good idea to test and find the issue before playing a guessing game that could cost a fortune.
  • bobby bob
    bobby bob
    have you done any work on it lately? may have dislodged a wire or left one loose , it happens.
    if you have power @ da coil & there's  no damage to the ign loom from da moudle in da cam cover , then just replace the complete ign system with a single fire Daytona twin tec system , da ign system only last for 4 to 6 yrs after that your running on luck 1998 is 17yrs old ,
