Online: GGUser731
fxst 07 engine light codes p1357 and p1358, what can i do to fix this problem?
  • 07fxst
    07fxst
  • 07fxst
    07fxst
    I have changed plugs and leads and engine light still comes on in top gears exceeding 110km/hr
  • chriso
    chriso
    P1357 Front Intermittent Secondary Combustion
    P1358 Rear Intermittent Secondary Combustion
  • 07fxst
    07fxst
    Yes, my bike has no symptoms just an engine light at top speeds, how can i resolve this from coming on again. thanks
  • Ando
    Ando
    Have you cleared your codes?
    Did you use the recommended plugs/leads? My guess would be wrong plugs, but your post seems to suggest you changed them because of the fault codes?.
  • 07fxst
    07fxst
    Yes i have cleared the history codes and no luck with the new screamin eagle leads and ngk DCPR7E plugs
  • 07fxst
    07fxst
    Im gonna try set the spark plug gap to 0.40, fingers crossed
  • 07fxst
    07fxst
    Change the leads again!!! to a new set of standard ones and all good now?
  • 07fxst
    07fxst
    Nope bike still does it again only in 5th and 6th gears going from 100km/hr with throttle?
  • 07fxst
    07fxst
    Has anyone fitted a high performance coil and why?
