Online: Stuart
08 Night Train, Engine noise 1/4 throttle
  • ryno_0000
    ryno_0000
    G'day All,
    I have noticed a strange sound from the left hand side of the engine, its like a scraping/ticking sound, when I'm rolling along then open up to about a 1/4 throttle, it will make the noise for about a second then as the revs get past that point it goes away. It doesn't make the noise if I slowly load the engine through the rev range.
    I noticed a week earlier when I was stuck in the CBD on a warn arfternoon, my legs were starting to get hot and the noise started after I got off the clutch and I took off at 1/4 throttle.
    Any help would be great.
    Ryno
    I would be thinking Wheel Bearings or Compensator Sprocket.
  • ryno_0000
    ryno_0000
    Wheel bearings I can change, with a compensator sproket? what could i do to diagnose that further?
  • Ando
    Ando
    Your bike is pinging
    have you had it dyno tunned
  • ryno_0000
    ryno_0000
    na I haven't at all, it was serviced at Sy's in sydney about 12months ago. They adjusted the map appaerently but it wasn't done with a dyno. I spoke with a shop and for some reason I believe your dead right Ando. Will a dyno tune sought out pinging?
  • AJ56
    AJ56
    Comp probably has come loose. it should be more noticeable at idle on the side stand as the comp will be rubbing against the primary case. Easy fix to tighten the nut. Also could be your primary chain slapping on the top of the case. This is due to the chain adjuster not taking up enough slack. There is a fix for that which I don't personally like as it can put extra strain on the crank.
    First gear hard accelerate to close to red line then throttle off and hard rear brake without locking up the wheel. Do this a couple of time and it will take up the extra slack in the chain. Or drop the primary case and knock the adjuster up a couple of notches. If you have a long this screw driver you may be able to get in through the clutch cover.
    A better fix is to put in an SE compensator setup. Better than stock and a Hayden M6 BT07 Primary chain adjuster. I run both on my 07 softail and it was the best changes I made to the bike.
  • ryno_0000
    ryno_0000
    ok, can you recommend any dyno places in SE QLD?
  • Drac
    Drac
    Pro cycle dyno at springwood
    Ph 38084003
  • ryno_0000
    ryno_0000
    Would a smart tune help in the meantime? or should I just leave it as is and wait for a tune???
  • ryno_0000
    ryno_0000
    Just an update.
    Took the bike to Fred at Pro Cycle Dyno. Bike runs sweet after he tuned it. So much smoother than before the tune. Power jumped from 77.97HP to 87.96HP. Torque jumped from 105.11 to 112.71. I just wanted the pinging to stop but it now rides unreal. Thanks Drac for the recommendation.
    Well done and good result. What cams are you running out of interest?
  • ryno_0000
    ryno_0000
    SE255's
  • ryno_0000
    ryno_0000
    http://www.hdforums.com.au/userpics/11097/20151207_201550.jpg
  • ryno_0000
    ryno_0000
    http://www.hdforums.com.au/userpics/11097/20151207_201616.jpg
  • ryno_0000
    ryno_0000
    Those links show the results from the tuning session.
