Online: Rextheute2022
Hog Lube Tips
  • shadowhand
    shadowhand
    18 years ago
    Primary fluid: Viscosity equivs:  5w30,10w30,10w40.    UN-friction modified good quality mineral oil.  For e.g. Mobil 1 Agri Super (10w30) or Shell Donax TF. ATF fluid is fine try get Dexron II or type F if u can.
    Transmission fluid:  80w90 GL-1 (20w 50 mineral/synth. oil for 5 speed) or GL-5 ( for 6 speed) gear oil.
    For e.g. Shell Spirax A  (GL-5)  or Synthetic UN-friction modified engine oil.  Viscosity- (15w50),(20w 50), (25w 60)  For e.g. Penrite SIN 25 (GL-1).
    Engine Oil: Ones that work:   Penrite HPR Gas. Penrite SIN 25.  Valvoline 4-Stroke M.Cycle Oil 15w 50.  Penrite Enduro. Mobil 1 V-Twin. Shell Advance 4T 20w50. Castrol Activ 4T 15w50. Pennzoil Motorcycle oil 20w 50. Revtech Motorcycle oil 20w 50.  H-D 360. HPR Diesel 20w60. BP Corse 25w 60.
    15w40 diesel oil. For e.g. Caltex Delo 400 MG or Rimula X (for winter use or blended in to mix) (!Becareful if high mileage bike and switching as it can unclog all the crap in engine!). (CF-4/CG-4/CI-4/CI-4 plus).
    Most likely these oil will work as well (I haven't tested them): Castrol Edge 25w 50. SIN 15 . Amsoil 100% SYN P.M.O 20w 50 (CI-4).  Revtech Syn. MTP 20w 50.  Penrite Everyday driving 20w50 & 15w40.
    If your bikes burning oil:
     Penrite Enduro or SIN 25 if u have always used synth.
    Steering head bearing grease:  -30 to 150. or -35 to 175C temp. range.  For e.g. Castrol APX T. Lower than -30 the better. Look for Lithium grease or molybedum added.
    Chain lube:  Wheel bearing grease with molybedum disulphide in it.  It won't fly off the chain and it has polymers in it. (Keep sand/dirt away from chain).
    Cable lube:  Mineral oil/ graphite mix (3:1)  1-2ML.
    Air filter lube:  Mineral oil.  Spray it on gauze if K&N filter with plant sprayer. Dry with hairdryer.
    If you live out a bit and need bulk oils there's these website i've seen:  Simply-online.com.au. & seemore.com.au.
    Hope these tips help somebody.
    'Harley-Davidson: Not just an ornament.'
    Take it easy.
