Online: bikenut57, brunosaustryau
Engineering NSW chopper
  • Raked
    Raked
    ok I have a bike I brought from vic 2002 indcon  chopper was registered in vic for the last 15 years, did the revs check it says compliance do in 2004-02 so I buy it, now in NSW the bike mechanic says I need to supply the engineers report.. the guy I brought it off tells me he didn't have one he just registered it there,
    pits got me stuffed what to do I have called a couple of engineering mobs and got 2 mental prices one for 4-5 thousand plus 90 per hour for any work and one for about 7 thousand - what the hell I almost fell off my chair when I heard these prices, does anybody know a engineer who does the job for a normal price in NSW or have any info on these situations where I might be able to get around doing this, each state has their rules but just seems to defy all logic to be all good in vic then the evil in NSW.
    Any advise would be good thanks.
    I would like to see a photo of it
  • Wimbo
    Wimbo
    Typical reason why we don't need State Governments.
  • 98superglide
    98superglide
    You should the rubbish the ACT get get up to. It's a shambles. Same as the helmet laws etc.
  • Raked
    Raked
    I wrote the letter to vic transport freedom of information so will see what comes back, I'll put up a picture just have to learn how to Shrink it so it fits in the page - just tried it and only had the wheel showing
  • Raked
    Raked
    Not sure what I did with this photo sorry guys for some reason I can only upload 1 picture
    At least it is parked on the best Egyption Fuckary Rug!
  • Raked
    Raked
    it's a nice rug that's for sure
  • Tat2_u
    Tat2_u
    Um that's a unicycle
    Would of liked to see the Bike together, then I can tell you what the problems are and how to fix them, but going on that photo it's only the Exhaust that will not pass.
  • Raked
    Raked
  • Raked
    Raked
    Hey Walka - just added new tree's today and grabbed a new rear guard - the rake it actually 820mm from the tree centre bolt top side to the front axel - that's in told is the problem the law says 550mm but the things a chopper, the new tree's brought it back for 950mm I might be measuring wrong ?
    Looks over 550 , it is the same rule in every state
  • Raked
    Raked
    Yeah I might typed it wrong it's massive
  • Raked
    Raked
    Worst case shorten the forks massively and buy and really big front rim the lift it up to level again, I'm going to ring p and l cycles in the morning to get their take on it
