front indicator relocation
  • Fat Tom
    Fat Tom
    Hi all, a question that maybe someone can put me on the straight and narrow with.I would like to relocate the front indicators on my 07 fatty from the bars to the forks. issue is I also have the detachable windscreen fittings. Can I have both ? I pressume if there is a kit it would fix to the same location. I dont want to put the driving bar lights on either
    sandshoe in advance
  • Ramakill
    Ramakill
    You can have both.  My FXST has fork mounted indicators and I was looking at a quick release screen. the indicator clamp has to go underneath the lower fork tree as the screen quick release clamps mount on top.  The forks should not compress that much to touch the indicator mount clamp.  Hope this makes sense and good luck.
  • Fat Tom
    Fat Tom
    Hi All, an update on my relocation dramas. Here is a photo of some custom brackets I made to allow me to still use my quick detachable windshield. It took no time to make and the windshield fits even better than before.
    I hope this helps someone out with the same predicament
