Online: Fletch1953, Ultramick
Ikon vs progressive front springs
  • Bcjones
    Bcjones
    Hey dudes I want to replace my front springs at stock height its just way to soft.
    Have any of you used the Aussie Ikon springs?
    Or should I just get progressive?
    .Thanks ????
  • fmacdonald
    fmacdonald
    Not sure this helps much but I used ikon springs on an airhead bmw and they were excellent and nice to deal with a local mob
    Ikon is the better
  • Bcjones
    Bcjones
    thanks guys
  • Nomada
    Nomada
    Anything is better
  • BAKES
    BAKES
    I paid $168, but that was in March 2014.
    Only got to fit them a month or so ago, due to a bad 18months of hospitals and operations.
  • brash
    brash
    These just drop in? Undo top clamp, fish out the stockers and drop the new ones in?
  • boggsy
    boggsy
    I was thinking about getting these. I ended up ordering Ricor Intiminators instead, so hopefully they turn up this week so I can put them in. The front suspension is dreadful on these things.
  • Bcjones
    Bcjones
    hey BAKES did you change the oil?
  • Bcjones
    Bcjones
    one other thing, how much spacer did you leave out of the top of the fork when off the ground? i think my spacer is to big, shes riding like a rock compared to before. i think it could be a little softer, but not heaps
  • BigJosh
    BigJosh
    Doc Robinson had good things to say about the Ikon range in the latest Heavy Duty, I'll be grabbing some for the FXDL when funds make themselves available, went over a stretch of road today that was so bad I thought I was going to break a hip.
  • Scott Bowen
    Scott Bowen
    I have progressive's in mine and it was like chalk and cheese. i think i had them fitted for $120ish
  • Howard
    Howard
    Put progressive cartridges in my sporty, so, so, so much better, but also put GAZI shocks on so hard to say which made so much difference. But, for about $1200 all up definitely worth it.
    A bit late but after, going through two sets of progressive springs n one of there shocks falling apart.
    i went to a guy in Sydney name Terry Haynes ( shock treatment) he did the forks to my weight n ordered custom shocks made to my weight and what i was useing bike for. that was the best i've had on a Harley, but not cheap. but then again eather are harleys. just thought i would mention, also there are other Guy's that are good at that too. custom set up for you is best! just changing springs only half what you need like the damping important too n the rear shocks need to be matched. but more for people that will use it, hard to explain, but makes for a safer ride. too.
