Online: John.R
tranny oil
  • slimjim
    slimjim
    Is there any better oil to use in 6 speed tranny,,done 16000 ks,its seems very clunky and hard to find nuetral,,,,
  • Retroman
    Redline heavy duty shockproof
    May be hard to find is all
    Available on Aussie ebay if you can't find it locally to you
  • chriso
    chriso
    Shockproof for me as well
  • chopa
    chopa
    Go the Shockproof you won't be sorry
  • robnicko
    robnicko
    good stuff here,
    http://www.penriteoil.com.au/products.php?id_categ=23&id_subcateg=171&id_products=378
    Can get your Redline from a guy in Greensborough, Victoria... sales@performanceclub.com
  • Independant_84
    Independant_84
    If it's hard to find neutral and shift try checking your clutch adjustment.Is it lunging forward when in gear idling with the clutch pulled in..
  • Odin
    Odin
    could some post a picture of the bottle that this Redline heavy duty shockproof comes in so we know what to buy
  • chriso
    chriso
  • Odin
    Odin
    thanks chriso, very much appreciated
  • Independant_84
    Independant_84
    I bought the redline shockproof  at autobahn.
  • kaos1369
    kaos1369
    I recommend Spectro six speed tranny oil, developed for the six speed box. Rollies will sort you out, google it and make up your own mind, it is good shit mate. Cheers.
  • AJ56
    AJ56
    try adjusting your clutch..
  • carcano
    carcano
    I have been using 85/ 90wt gear oil in my gear boxes since 1981 never had a spot of trouble with a gear box after all its a Harley box and like me old mate told me it is agricultural.
    Good luck with whatever you choose.
